Mark_P87
Jan 13, 2020Aspirant
Ethernet Light Orange
We have purchased a WAC505 for our office to provide Wi-Fi access for visitors. This has been plugged into the office ethernet port which is live and powers the device but we have a orange light for ...
- Jan 23, 2020
Worth a test: Take a healthy CAT5A or better patch cord (with eight strands/four pairs), and connect WAC505 and the GS724Tv3 direct.
As the switch is not a PoE model, are you using a "correct" power supply?
Mark_P87
Jan 23, 2020Aspirant
Thank you for your reply, we are running a Netgear GS724TV3-A59F, i will have a look at the wiring see if this helps.
schumaku
Jan 23, 2020Guru - Experienced User
- Mark_P87Jan 27, 2020Aspirant
All sorted, swapped the cables out.
Thank you
