junjun02
Jan 08, 2026Aspirant
How to Retain Static IP Address on Netgear WBE710 After Reboot or Firmware Update
I am using the Netgear WBE710. Currently, I have enabled the DHCP server on the router and assigned an IP address to the AP by setting a reserved IP for its MAC address. Ideally, I would like to se...
junjun02
Jan 12, 2026Aspirant
Thank you for your answer.
The AP in Insight managed mode is.
Hove you configured the router to assign static IP addresses via DHCP? I think that if you don’t first assign an IP address to the AP via DHCP, any settings made on Insight will not be applied.
