Jglacken
Jul 10, 2024Aspirant
https://www.netgear.com/support/product/wax214/
Access point has two networks which have been running fine. This am the networks show up but iPads cannot connect to either one. Proper lights are showing on the top. Rebooted by disconnecting bot...
- Jul 11, 2024
I have it sorted. It doesn’t like Safari.
michaelkenward
Jul 10, 2024Guru - Experienced User
- JglackenJul 10, 2024Aspirant
Not understanding the link
- michaelkenwardJul 10, 2024Guru - Experienced User
Did you read the page at the end of the link?
I agree that the page is way too complicated, but it boils down to turning off the random MAC feature on the iCrap.
I turned off the Mac stuff. Still cannot connect to the two networks on the AP.
