Jglacken
Jul 10, 2024Aspirant
https://www.netgear.com/support/product/wax214/
Access point has two networks which have been running fine. This am the networks show up but iPads cannot connect to either one. Proper lights are showing on the top. Rebooted by disconnecting bot...
- Jul 11, 2024
I have it sorted. It doesn’t like Safari.
Nivedita
Jul 10, 2024NETGEAR Expert
Hi,
Config-only SSID will stop broadcasting, if that SSID is idle for 15mins. Hence you might not seeing the config-only ssid.
Config-only said reappears once after AP reboot, if you want to check the AP IP address and wireless configurations details.
Does both network (SSID) is enabled with 2.4G and 5 GHz ?, what security modes are configured ?. what Channel configuration?
Did you try connecting iPad moving little near to AP, please check channel configurations and try to set channel according to your congested environment .
Is issue only with iPad?, what's the version?.
Jglacken
Jul 11, 2024Aspirant
I have finally created a working network on the access point. It is a 5.0 network.
i want to add one other network for 2.4, but cannot seem to do that?
how to do it please?
