Jglacken
Jul 10, 2024Aspirant
https://www.netgear.com/support/product/wax214/
Access point has two networks which have been running fine. This am the networks show up but iPads cannot connect to either one. Proper lights are showing on the top. Rebooted by disconnecting bot...
- Jul 11, 2024
I have it sorted. It doesn’t like Safari.
schumaku
Jul 11, 2024Guru - Experienced User
What exactly are the the plans and intentions?
Technically, you can map any SSID, any band, to any VLAN and IP subnet - permitting these VLANs and subnet exist can reach the Internet or other internal VLANs and subnets, and a workable DHCP service is available for each of these VLANs of course.
Keep in mind these WAX2xx are intended for standalone deployments. For supporting seamless roaming, security different from WPA2-PSK for example WPA3-SAE or RADIUS based authentication or other portals, the Insight managed WPA6xx or WBE7xx re much better suited.
