Jglacken
Jul 10, 2024Aspirant
https://www.netgear.com/support/product/wax214/
Access point has two networks which have been running fine. This am the networks show up but iPads cannot connect to either one. Proper lights are showing on the top. Rebooted by disconnecting bot...
- Jul 11, 2024
I have it sorted. It doesn’t like Safari.
Jglacken
Jul 11, 2024Aspirant
Thank you for your reply. I have a 5.0 network now installed on the AP. Now I want to add a second network with 2.4 as they have better range. How do I add a second network?
Nivedita
Jul 11, 2024NETGEAR Expert
You can add upto 4 SSID's from wireless settings page, 2.4G, 5GHz, 2.4GHz and 5 GHz dual band.
Open AP page using DHCP IP address, Enable the SSID radio button, configure SSID name, passphrase and apply changes.
