Jglacken
Jul 10, 2024Aspirant
https://www.netgear.com/support/product/wax214/
Access point has two networks which have been running fine. This am the networks show up but iPads cannot connect to either one. Proper lights are showing on the top. Rebooted by disconnecting bot...
- Jul 12, 2024
I have it sorted. It doesn’t like Safari.
Nivedita
Jul 12, 2024NETGEAR Expert
You can add upto 4 SSID's from wireless settings page, 2.4G, 5GHz, 2.4GHz and 5 GHz dual band.
Open AP page using DHCP IP address, Enable the SSID radio button, configure SSID name, passphrase and apply changes.
Jglacken
Jul 12, 2024Aspirant
I am afraid I don’t know how to open the AP. I know the IP address but …
- JglackenJul 12, 2024Aspirant
- schumakuJul 12, 2024Guru - Experienced User
Can you please be a little bit more specific? Can't see any issues on the dead-simple WAX21x Web UI, accessing the WAX214, a "v1" version, running on 2.1.1.3 from Safari on an iPhone - typically the biggest challenges for Web applications.
Leaving alone the inability defining the VLAN ID in OWE security SSID (reported a long time ago)....
