Pappapappa
Jun 21, 2022Aspirant
Mesh WAC564 to WAX620
Hi i am trying to mesh a WAC564 wifi extender to a WAX620 Wireless Access Point. The WAC564 is located in one building, with the WAX620 in another building. The buildings are approx 25 metres apart. ...
Pappapappa
Hi the buildings are simple concrete block construction in our garden. There is nothing in between the buildings (no trees etc), just open land.
Jun 21, 2022Guru - Experienced User
Concrete is one of the best blockers of wifi. And if both buildings have exterior walls made with concrete, its going to significantly deteriorate the signal. I'd be betting on thats why it works if they're in the same building but not once you separate them.
