ugale11
Mar 05, 2024Aspirant
MS108EUP Switch and WAX630E https certificates
Hello guys, I am having some issues setting up https ssl certificates for these new devices I bought, everything else is working perfectly. About the MS108EUP switch, whatever PEM i try to create i...
schumaku
Mar 05, 2024Guru - Experienced User
ugale11 wrote:
About the MS108EUP switch, whatever PEM i try to create i am always getting the invalid format error, no matter what i try. Even if i let the switch generate a certificate and then upload it manually back, i get an error too. I would like to use my self signed one with my CA.
Try not going beyond of SHA 256 and RSA 2048 to start with on the switches.
ugale11 wrote:
For the AP WAX630E is it even possible to do https? I don't see any option for it, i just see an FQDN setting which btw doesn't even accept my LAN custom domain.
Just with the default self-sighed certificates I fear. Netgear has apparently not implemented anything useful on the WAX6xx, neither the ability to neither create CSRs nor the ability to generate self-signed certificates nor the ability to import PKI signed certificates. Sigh 8-(
Then again, for the (in my opinion strange, like for a Web host) FQDN input field [the AP must be accessed using exactly this domain as configured, Netgear appears to see this as kind of an additional security [by obscurity] feature! But then, this appears to be limited somehow, we can't just "randomly" define FQDNs, and without random selected domains. Admit, I have not seen exact rules or documentation what is accepted there. Will try to challenge Netgear again on these subjects 8-)
