ugale11
Mar 05, 2024Aspirant
MS108EUP Switch and WAX630E https certificates
Hello guys, I am having some issues setting up https ssl certificates for these new devices I bought, everything else is working perfectly. About the MS108EUP switch, whatever PEM i try to create i...
ugale11
Mar 10, 2024Aspirant
ugale11 wrote:Hello guys,
About the MS108EUP switch, whatever PEM i try to create i am always getting the invalid format error, no matter what i try. Even if i let the switch generate a certificate and then upload it manually back, i get an error too. I would like to use my self signed one with my CA.
For the AP WAX630E is it even possible to do https? I don't see any option for it, i just see an FQDN setting which btw doesn't even accept my LAN custom domain https://9apps.ooo/ .
Thanks for the help
I got this,...
- schumakuMar 10, 2024Guru - Experienced User
ugale11 wrote:
ugale11 wrote:
which btw doesn't even accept my LAN custom domain 9apps.ooo .
I got this,...
Ok, excellent discovery, thank you!
Multiple things are coming together here:
- Netgear does apparently not accept perfectly valid Internet top-level domains like your .ooo
- None of the WAX6xx does accept your valid domain currently, clearly a non-allowed restriction, to be addressed by Netgear. I'll push this to Netgear on a different channel, but I'll allow tag RaghuHR here.
- Not a factor here, however this FQDN is the one intended to reach the WAX6xx admin Web UI - it might be cumbersome (not forbidden however) not using a host level domain for each host to be addressed, like wax630a.9apps.ooo for example
-Kurt
