diehardbattery1
Apr 12, 2024Guide
Multiple WAX630E AP's, only assign certain SSID's to each?
So I have 3 WAX630E AP's running. There is a guest network configured as well. I want the guest network to be available on only 2 of the AP's. When I remove the SSID from the AP I do not want to have...
diehardbattery1
Apr 13, 2024Guide
It seems odd to me that Insight won't let you do this, but I suppose there are valid reasons why. No, I have not posted this elsewhere in the community, however, I did post this on Reddit on the Netgear subreddit and was directed here.
schumaku
Apr 13, 2024Guru - Experienced User
Ok, we know that sone wannabe smart Spanner and Scammers are often copy posts from Reddit, difficult to impossible for is normal user to check reliability. In fact, this happened to your Reddit post, too and shameless copies appearing here. If in question, we tend to report these to the moderators.
