AlanW365
Oct 01, 2023Aspirant
My WAX206 Router Continually Drops WiFi Signal
I manage a small network for my church. We have small business Internet service through Spectrum, entering the building on 75 Ohm coax into a business class DSL modem, then directly connected to thei...
tchubaba
Oct 02, 2023Guide
Have you attempted to take a look at the AP's logs? With any luck there could be something in there that could give you clues as to what may be going on. Try looking around the time which the issue usually happens. Here's a link to that AP's manual. Page 125 talks about how to configure, read and send them.
https://www.downloads.netgear.com/files/GDC/WAX202/WAX202_WAX206_UM_EN.pdf
Also, are you using the latest firmware for the AP? I didn't see in the release notes for the firmware versions available for this AP any which indicates a fix for this issue, but it's worth a shot making sure you are running the latest.
AlanW365
Oct 03, 2023Aspirant
Thanks, I will review the log files. I will also check the firmware version; however, I think it did an update last week, so it should be current.
