dean1011
Jun 11, 2023Follower
Netgear wax620 VLAN
My netgear wax620 is connected to my trunk port 10,20,30. I have unifi ap and it’s working over there where I have to create a network and vlan, and bridge wifi there. But on my netgear wax620, i can...
schumaku
Jun 11, 2023Guru - Experienced User
Insight Cloud Managed WiFi 6 AX3600 Access Point Model WAX620 User Manual
p.70 ff. "Change the VLAN ID for a WiFi network "
BasuKhodanapur
Jun 12, 2023Apprentice
Hello dean1011
Sure, we can help you in configuring vlan's.Can you please provide below details?
1. Is setup insight managed or standalone?
2. Where is the dhcp server running?
3. In between DHCP server and WAX620 -Is there switch? If yes, then all mentioned vlans are tagged to the port where WAX620 connected and untag management vlan
4. If possible, network topology
Thanks,
Basavaraj
