NMPNMPNMP
Mar 15, 2022Aspirant
Netgear WAX630 Official power supply
Hi, I don't have a 802.3bt capable switch so as I understand it I'll need to use a power supply to get full performance from the Netgear WAX630. Could someone confirm the model number of power s...
schumaku
Mar 15, 2022Guru - Experienced User
The official Netgear power supply for these devices is the PAV12V35. For Europe, the SKU is PAV12V35-100PES, for the North Americas and other 100-120VAC with the US power plugs, the SKU is PAV12V35-100NAS. Blunt theory, for the UK plug, it would be PAV12V35-100UKS - however I can't find it from here.
Of course, plenty of second source power supplies available with similar specs.
I would suggest to look for a true 802.3bt PoE (PoE++) injector coming with UK power supply - much nicer than having power bricks near to the APs.
NMPNMPNMP wrote:
Alternatively would something like the ubiquiti 60w POE injector work? From what I can tell this product is non standard but will happily supply over 30w over ethernet.
Beware! Most Ubiquity injectors are passive, non-standard-PoE, and using voltage depending on the intended usage - POE standard equipment won't negotiate power from passive equipment. You need to look-out for IEEE standard PoE devices for the majority of Netgear PoE devices, here 802.3bt.
