Caden_Cotard
Mar 28, 2023Aspirant
Netgear WAX630E- Beacon Protection Feature
Hi all, I have been using Netgear Triband access point Model Number - WAX630E. I noticed this while capturing that without enabling the beacon protection some of the beacons are being transmitted wit...
Caden_Cotard
Mar 29, 2023Aspirant
If there is an option to enable and disable the beacon protection provided in netgear access point, it would be an added advantage for me to check the behaviour. That's the reason i asked about how to enable and disable it.
Secondly, i didn't enabled it. So i wanna know why the access point transmitting protection beacons (not in a regular interval)
schumaku
Mar 29, 2023Guru - Experienced User
Start with do disabled WPA3 (where it's a default requirement) so use WPA2 only..
Needless to say WPA3 is the standard for 6 GHz.
- Caden_CotardMar 29, 2023Aspirant
I'm using the Netgear access point in 6GHz so I should use WPA3. In 2.4 and 5 bands the beacons are not protected even with wpa3 enabled. Im getting protected beacons only when i run in 6GHz. Is there any time interval for this transmission of protected beacons?
- schumakuMar 29, 2023Guru - Experienced UserWhen I have it right, the control is available by SSID
Under 802.11w (PMF), select one of the following radio buttons:• Mandatory. Requires devices to use PMF. Devices that do not support PMF cannot connect to the WiFi network. If you select WPA3 Personal authentication or WiFi enhanced open authentication, PMF becomes mandatory automatically.• Optional. Lets the access point automatically activate PMF based on whether devices can support PMF.• Disable. PMF is disabled for the WiFi network.- Caden_CotardMar 29, 2023AspirantPMF protects Deauth, Reasso only right. Does it give protection for beacons also. In most of the sites are saying the same. No where it's mentioned as a PMF protection is for beacon also. So if enabling PMF protecting the beacon of the access point then I should receive protected beacon always and in a regular interval right. But I'm my case the chance to get a protected beacons is very rare. I just wanna know how or what triggers such an operation from the ap side.
Note: I did not happen to see any protected beacons from other 6E aps which I'm using with netgear. Only in netgear I'm seeing this event. I'd say it's such a good implementation but i wanna know the reason behind it (why most of the times I'm not getting beacon protection when PMF is enabled as per your analogy but the deauths and reassos getting protected)
