dfunkt
Apr 06, 2023Aspirant
Netgear WAX630E and Netgear MS108EUP multi gig - still slow wifi speeds - help!!
My setup House included Araknis 500 and 200 series AP and switch combo with about 350ish up/down speed Internet: AT&T lightspeed fiber connection at Current Speed (Mbps)Current Duplex 1000...
schumaku
Apr 07, 2023Guru - Experienced User
Your ATT provided Modem/Router does support MultiGig on the blue 5 GbE port, so a full 2.5 GbE is reached from your WAX630E through the MS108EUP.
No odd Mesh configured on these WAX? Usual reasons for non-usual WiFi performance is in the channel layout and availability, not fully open max bandwidth, overlapping wireless equipment (interferences).
dfunkt
Apr 07, 2023Aspirant
As far as the AT&T provide modem/router, yes, the 5G ethernet is enabled as you can see below.
Also, the MS108EUP is plugged into that port as shown with the picture and with the 68 active devices showing up in the interface picture.
And this is the picture of the Netgear Insight app for the mesh portion, which doesn't show anything since I don't have any non-root or extender devices.
But certainly thanks schumaku for the checkpoint ideas. Anything else I might be missing?
