podex's avatar
podex
Tutor
Dec 09, 2020
No Internet access after WAC540 firmware update (9.1.0.13)
I am using 3 WAC540 in an Inside configuration at my restaurant. It worked fine until I updated the firmware to the current version 9.1.0.13.   The setup is quite simple, just the 3 devices connec...
  • RaghuHR's avatar
    RaghuHR
    Dec 15, 2020
    Hi podex
    Have you enabled client isolation? Could you please save the detailed logs from monitoring page and send it to us? You can upload into google drive and send me link via PM.
    Thanks,
    Raghu
