HarmonHodge
Apr 21, 2023Star
Outdoor access point
I am looking to provide better wifi on my deck. I have a wired network from a ATT Remote Gateway (1 Gig) to a Netgear unmanaged switch. I have CAT 6 to an LG TV, Netgear WAX 620 and a couple of jacks...
- Apr 21, 2023
HarmonHodge wrote:
I am looking to run CAT 6 to my deck. Does Netgear make a small access point I can plug into the wall outside (under the eaves and GFCI outlet) and connect to CAT 6?
Alternate to an expensive power installation with GFCI, connector boxes and space for huge power bricks, consider a PoE+ or PoE++ wireless access point on a CAT6 or better cabling.
Cumbersome is that enclosures for wireless AP are not inexpensive.
schumaku
Apr 21, 2023Guru - Experienced User
- HarmonHodgeApr 21, 2023Star
The GFCI is already there. I was just planning to run CAT 6 to it and plug in an Access Point/POE. Is there a particular model Netgear makes to satisfy this? I see the other response above.
Thanks
Harmon
The POE + is the way to go as you both suggested. Thank you for your help. Single Cat 6 and no power supply or GFCI needed. Just need to figure out which one now I know this sort of beast exists.
Harmon
- HarmonHodgeApr 22, 2023Star
I bought the NetGear Wireless Outdoor Access Point (WAX610Y) per everyone's input. Will run a length of CAT 6 and fire it up once it arrives.
Thanks!
Lynwood (Harmon) Hodge
- plemansApr 22, 2023Guru - Experienced User
hope it works great!
