HarmonHodge
Apr 21, 2023Star
Outdoor access point
I am looking to provide better wifi on my deck. I have a wired network from a ATT Remote Gateway (1 Gig) to a Netgear unmanaged switch. I have CAT 6 to an LG TV, Netgear WAX 620 and a couple of jacks...
- Apr 21, 2023
HarmonHodge wrote:
I am looking to run CAT 6 to my deck. Does Netgear make a small access point I can plug into the wall outside (under the eaves and GFCI outlet) and connect to CAT 6?
Alternate to an expensive power installation with GFCI, connector boxes and space for huge power bricks, consider a PoE+ or PoE++ wireless access point on a CAT6 or better cabling.
Cumbersome is that enclosures for wireless AP are not inexpensive.
Apr 21, 2023Guru - Experienced User
Why not look for an outdoor rated POE powered access point like the WAX610y?
HarmonHodge
Apr 21, 2023Star
Thank you. This is what I was looking for. it will be under the eves but still exposed. I will check into this one.
Harmon
