bartosz-l
Apr 08, 2021Aspirant
re-discover managed access point
Good afternoon, controller: 7600 access point: WAC720 Access point was no longer used, disconnected from network, and removed from managed access points list. Now I need it back to work with t...
JohnC_V
Apr 09, 2021NETGEAR Employee Retired
If it is the same wireless controller, you don't need to re-install the standalone firmware but it will depend if the AP is running on the same firmware as the controller. if you are not sure about the installed firmware then It would be best to install a standalone firmware and discover it using the controller.
John
NETGEAR Community Team
bartosz-l
Apr 09, 2021Aspirant
thank You for Your reply.
So, assuming it is same firmware:
When I remove (configured and working) access point from 'managed AP list' then I should be able to re-discover this AP again if I use Discovery wizard?
regards
- JohnC_VApr 16, 2021NETGEAR Employee Retired
That is correct. Just use the discovery wizard from your controller and you may be able to detect the access point. Just let me know if that will not work.
John
- bartosz-lApr 19, 2021Aspirant
hi, thank You for Your reply,
unfortunatelly this did not work.
I tried auto discovery and picked subnet as well
regards
- JohnC_VApr 20, 2021NETGEAR Employee Retired
Please open a ticket on NETGEAR support and please let them know the status of your access point. You may also include this thread.
John
