pgw85706
Mar 08, 2023Tutor
WAX620
Hello. I need to strengthen my wireless coverage in our 3 story home. Please confirm to install 1 WAX620 on each floor (3 total) connected to a GS308EP PoE+ (123W) switch are compatib...
pgw85706
Mar 08, 2023Tutor
The switch will connect to a Linksys EA8500 router (for now).
You want to wire these repeaters as Access Points to a GS308EP switch? That is my thinking unless there is a problem with this config.
Why did you pick network managed devices from Netgear's business range? I am seeking a rugged, industrial grade configuration. I like the coverage and range of the WAX devices. All APs will be installed with hardwire ethernet cable back to the switch. I am working to hardwire all my "fixed" devices....TVs, printers, LAN storage, pool control, etc to reduce the wifi load.
I have studied the mesh network offerings promoted for home applications. They seem priced high to me and the WAX devices seems like a stronger, more cost effective solution.
BasuKhodanapur
Mar 10, 2023Apprentice
Hi Patrick
Thanks for writing to us.
Could you please share below details, we can help you in no of AP's required to cover 3 story home.
1. floor map with measurement
2. No of clients you are planning to connect to each WAX620 AP.
3. Any other particular requirement.
Best Regards,
Basu
- abacqdghfthMar 10, 2023Guide
Netgear has a no obligation and free wifi planning services. the team of experts will use industry standard wi-fi survey and planner software to estimate the number and placement of APs and send you an report.
please check out
https://www.netgear.com/av/services/prowifi-designsupport/
and send an e-mail today. someone will contact you in soon.
- pgw85706Mar 10, 2023Tutor
Thank you. I will make a submittal and see what happens.
