ivant088
Aug 20, 2022Aspirant
WAX630E slow when managment lan is changed
Wifi speed on the WAX630E slows to around 40mbps on both upload and download when management lan id of the access point is changed. If it is left as 1, speed is normal. Previous access point from a d...
bamhm182
Dec 13, 2022Tutor
I was less than optimistic when I posted the other day, but I was able to obtain a beta firmware which seems to have resolved this issue. I will continue to keep an eye on it, but hopefully this beta fix will hit stable soon.
d1337
Dec 31, 2022Aspirant
Hi All, facing the exact same issue, where did you find this firmware? would like to try this also.
