PATTERSON108
Apr 10, 2024Aspirant
Re: WAX630E VLAN bug
All, I have a WAX625 AP on firmware version 10.8.5.7 and managed by Insight. I have confirmed the exact same issue with wireless devices being in different wireless vlans with having the ability icmp...
schumaku
Apr 13, 2024Guru - Experienced User
Issue is independent of the management.
Interesting to know, several vendors had been affected over the years by the very similar issue... cause was related to some hardware acceleration enabled, and also active on some Netgear AP models. This is something Netgear has to figure out with the chip vendor very likely
The problem does not affect the usual pure AP modes for connecting to the LAN or the Internet. That's why there are only very few reports of this issue.
- PATTERSON108Apr 15, 2024Aspirant
Would it help if you knew more about the products that were connected to find a solution? If I connected a second network cable could I push the traffic to another vlan to fix the issue?
Is there another Netgear AP with a 4x4 in the WAX series that is not effected by this issue?
Mark
