roach112683
Mar 29, 2022Tutor
Routing between subnets with 2 routers
I have a question for the community. I tried to look this up but no luck so if I missed something in a solved post please let me know. I have a Netgear C700v2 as my ISP gateway. I was getting ...
roach112683
Mar 29, 2022Tutor
23 connected on the C7000vs (Max 30) and 3 (wired) 1 (wifi) on the WAX202
WAX202 is plugged into the C7000v2.
At one point I was able to ping the printer but it's not showing up as being connected to the network when I get on the subnet wifi (WAX202)
Mar 29, 2022Guru - Experienced User
You can have more than that connected, especially if they're hardwired.
Its usually 32 devices per band. If they're higher bandwidth devices, its less but you can connect that many.
You'd be better off to put the WAX in access point mode.
- roach112683Mar 29, 2022Tutor
Ok. I also have the netgear managed switch that can do VLANs. Should I put some stuff on the VLAN? Will that help at all?
- plemansMar 29, 2022Guru - Experienced User
shouldn't need to.
I'd simply leave the c7000 in router mode and the wax in access point mode.
Just make sure the wireless networks are using different channels to prevent interference.
- roach112683Mar 30, 2022Tutor
OK seems to be working so far.
Thanks
