az_taka's avatar
az_taka
The wireless bridge setting of WAC720 is not saved.
The enable/disable is not saved in the wireless bridge setting of WAC720. However, when it sees on the WEB setting screen, it has not become effective though the wireless bridge itself is moving when...
  • RaghuHR's avatar
    RaghuHR
    May 21, 2020
    az_taka
    Did you clicked on Apply after enabling WDS?
ProSupport for Business
