az_taka
May 18, 2020Aspirant
The wireless bridge setting of WAC720 is not saved.
The enable/disable is not saved in the wireless bridge setting of WAC720. However, when it sees on the WEB setting screen, it has not become effective though the wireless bridge itself is moving when...
az_taka
May 19, 2020Aspirant
Thank you for your reply.
Answers will be listed.
a. Was everything working fine before?
→It's the same as it is now.
b. Have you tried clearing the cache of the browser you are using or tried using other browsers like Firefox or Google Chrome? If not yet, kindly try it then access the web-GUI of your WAC720 and check if the same problem will occur.
→I've tried it after clearing the cache in various browsers and it's the same.
c. What is the current firmware version of your WAC720? If ever it is not yet the latest version, I suggest you to update it. The latest WAC720 firmware version is v3.9.1.0 and you can download it here.
→I'm using the latest v3.9.1.0.
Regards
