fanjai
Dec 07, 2021Follower
Using VLAN in WAX620
Hi May I ask some questions about using the VLAN for specific SSID please? Actually I do have 2 different SSIDs on my AP already and I am planning to setup one of them for guest WIFI usage. ...
schumaku
Dec 07, 2021Guru - Experienced User
Of course you can.
Does your router offer multiple networks (like normal Internet and guest), either on two ports, or by offering VLAN support where you can tag one of the two (typically the guest one) for travelling over the same network port and connection?
