coaster13
Mar 28, 2021Initiate
wac 124 constantly logs you out of settings
I have a WAC124 and everytime I log into the settings, it logs me off in less than a minute. I can barely change any settings before it logs me off and I have to log back in. This is very annoying. ...
DaneA
Apr 11, 2021NETGEAR Employee Retired
Are able to access the web-GUI and login just fine before?
Are you trying to access the web-GUI via a hardwired connection to the WAC124 or via wireless connection?
Is your WAC124 set to Router Mode or AP Mode?
Have you tried to turn off/on your WAC124? If not yet, kindly try it turn off/on then check if you will be able to access the web-GUI then navigate through it without logging you out in less than a minute.
DaneA
NETGEAR Community Team
focaldepth
May 10, 2021Initiate
I agree with the OP, the login time out is far too short for all but the most trivial setup needs.
