Vectro
Jul 27, 2019Aspirant
WAC-510 VLAN to SSID Association on CIsco RV325
I had been using Cisco APs until I found that a lot of them have a throughput problem. WAC-510 has better throughput and clustering works well for me. Only trouble I've had with it is getting differe...
- Jul 31, 2019
WAC5xx (WAC510, 505, 540...) all support VLAN<-->SSID mapping.
Most of the time, when we debug clients not getting DHCP. it will normally be due to some conf error upstream.
Coming to your network :
Router==TrunkPort(1,25,100,5,6)====Switch====TrunkPort(1,5,6) === AP ~~~SSID1-VLAN5~~~ Client
Can you check if the DHCP request packets are reaching your router
You can capture packets on the AP, download it to your PC and check the VLAN mapping of DHCP packets.
sameway you can port mirror switch/router and check on that too.
We need to see, if your router did get a DHCP request packet from client and responded. the switch has to tag the response back and send it to AP. then AP will be able deliver it back to the right client on the right SSID.
other basic things:
make sure WAC510 is connected to WAN/PoE ports.
WAC510 is in AP mode.
Cisco RV325 Router
VLAN 1 - Default
VLAN 25 - Guest
VLAN 100 - Voice
VLAN 5 - WindowsVLAN 6 - Linux
WAC-510 Access Point
SSID 1 (Windows) --> VLAN 5
SSID 2 (Linux) --> VLAN 6
AP LAN Config
DHCP
Untagged VLAN 1
Management VLAN 1
schumaku
Jul 31, 2019Guru - Experienced User
WAC SSID-VAN config looks OK - works like this in many instances for us. Strange....
nmhTester
Jul 31, 2019NETGEAR Employee Retired
other basic things:
Cisco RV325 Router
VLAN 1 - Default
VLAN 25 - Guest
VLAN 100 - Voice
VLAN 5 - Windows
VLAN 6 - Linux
AP LAN Config
DHCP
Untagged VLAN 1
Management VLAN 1
