Jessicasdd
Sep 07, 2022Guide
WAC104 - No internet, Secured
We have two WAC104 wireless access points. One works great, no issues, always let's you get to the internet. The second one, however, does not let anyone to the internet all of a sudden. It was worki...
- Oct 11, 2022
So I didn't get a chance to take it home last night but I found the issue today and you were right!!! There was a rule missing from the firewall giving it access to the outside world. I honestly thought that was the first rule I created, and maybe I did and it just didn't save it, or maybe I didn't. I have no idea. All I know now is that I added the rule and now I have access to the internet.
I am still wondering how it was working when I first connected it. LOL
Thank you so much for all of your help. It is truly appreciated!!
All the best,
Jessica
Jessicasdd
Sep 07, 2022Guide
I cannot connect it directly to the modem. The modem is connected to the firewall. Disconnecting will take the entire company down. Not worth it over one access point. 🙂
As I said in both posts... It was working fine last week and stopped yesterday. Everything else is working, including the other one just like it connected to the same firewall.
Is there something in the access point that can be set so that the computers don't see it as a public? My phone says it can't get an IP address. The IP assigned on the computer is 169.... which is nothing. It should be picking something up in the 190.168.45.0 range.
Thanks,
Jessica
Sep 07, 2022Guru - Experienced User
I get you can't just connect it to your modem.
And I get the one works fines.
But in AP mode, the access point isn't handling dhcp/ipaddress at all. The firewall is.
Which is why I recommended testing it directly.
Any chance you can bring it home to test on a home router?
Whenever it comes to business environments/firewalls, it gets more complicated
- JessicasddOct 10, 2022Guide
So I figured out the DHCP issue. I must not have saved the setting in the firewall when I originally set it up. I set it up identical to another setup in the firewall but when i double checked it the DHCP info was missing. So I fixed that and am now getting an IP address but still no internet.
I am going to see if I can take it home and see what's wrong with it.
Thank you for all your help and suggestions. Working on 40 things at once and trying to remember everything that's done.
Thanks,
Jessica
- JessicasddOct 11, 2022Guide
All the best,
Jessica
- plemansOct 12, 2022Guru - Experienced User
glad you got it figured out and it was a simple mistake 🙂
You might mark it solved so others aren't still trying to fix it
