Jessicasdd
Sep 07, 2022Guide
WAC104 - No internet, Secured
We have two WAC104 wireless access points. One works great, no issues, always let's you get to the internet. The second one, however, does not let anyone to the internet all of a sudden. It was worki...
- Oct 11, 2022
So I didn't get a chance to take it home last night but I found the issue today and you were right!!! There was a rule missing from the firewall giving it access to the outside world. I honestly thought that was the first rule I created, and maybe I did and it just didn't save it, or maybe I didn't. I have no idea. All I know now is that I added the rule and now I have access to the internet.
I am still wondering how it was working when I first connected it. LOL
Thank you so much for all of your help. It is truly appreciated!!
All the best,
Jessica
Jessicasdd
Oct 10, 2022Guide
So I figured out the DHCP issue. I must not have saved the setting in the firewall when I originally set it up. I set it up identical to another setup in the firewall but when i double checked it the DHCP info was missing. So I fixed that and am now getting an IP address but still no internet.
I am going to see if I can take it home and see what's wrong with it.
Thank you for all your help and suggestions. Working on 40 things at once and trying to remember everything that's done.
Thanks,
Jessica
Jessicasdd
Oct 11, 2022Guide
All the best,
Jessica
- plemansOct 11, 2022Guru - Experienced User
glad you got it figured out and it was a simple mistake 🙂
You might mark it solved so others aren't still trying to fix it
