Michael-OakPark
Jul 30, 2021Follower
WAC104 Wireless Access Point
Hi Netgear Community, My plan is to use the WAC104 as a bi-directional bridge between a Netgear PoE+ Switch (GS305Pv2) and a WiFi Network that has DHCP. The Netgear PoE+ switch has a POE security...
DaneA
Sep 08, 2021NETGEAR Employee Retired
Welcome to the community! :)
As I understand your initial post, the security cameras (which are directly connected to the GS305Pv2) and the WAC104 are going to be on the same subnet. Am I right? If yes, then the WAC104 will work on network setup you are trying to implement.
DaneA
NETGEAR Community Team
schumaku
Sep 12, 2021Guru - Experienced User
Does the primary WiFi router support WDS bridging as a Wireless Base Station? Most WiFi routers or APs simply don't.
The WAC104 certainly does support a WDS wireless bridge mode as a Wireless Base Station, and for one or more Wireless Repeaters in a single hub and one or multiple spokes system.
The WAC104 however is not a universal wireless extender allowing to connect to generic wireless access point devices or WiFi routers.
