froudaut
May 01, 2021Follower
WAX 610 WIFI6 AX1800 BUG with VLAN attached to SSID for DHCP Discover
Hi, Hoping that it will hit developers concerned ;-/ Indeed it is possible to attach VLAN to SSID but all packets are not forwarded through the defined VLAN. In particular DHCP Discover use the...
Giancarlo2021
May 18, 2021Aspirant
That is my experience: two WAX 610 (AP1 and AP2) in bridge mode, AP1 is connected to the Telco internet router;
I configure an AX1800 as Extender near the AP2; the clients connect but don't go in internet. They can navigate without problem in the WiFi Lan, but no one of them can exit in internet. I have seen they have ad DNS the IP address of the extender. I changed it to the one of Google (8.8.8.8, 8.8.4.4) and the one of the router (192.169.1.1) without success.
Any idea? the AX1800 mesh extender is not compatible with a bridged WiFi lan?
thanks
- Giancarlo2021May 18, 2021Aspirant
I add this image: the configuration is right, but the clients don't go in internet
thank you
