froudaut
May 01, 2021Follower
WAX 610 WIFI6 AX1800 BUG with VLAN attached to SSID for DHCP Discover
Hi, Hoping that it will hit developers concerned ;-/ Indeed it is possible to attach VLAN to SSID but all packets are not forwarded through the defined VLAN. In particular DHCP Discover use the...
schumaku
May 19, 2021Guru - Experienced User
froudaut looks like an obvious bug. Unclear is the firmware version, the VLAN config, which virtual AP is involved.
Have requested moving this thread to the Business WiFi section.
Giancarlo2021 The WA610 set-up with it's does work to that point and the extended LAN?
Whatever AX1800 extender, whatever WAX610 firmware, whatever extender model and firmware .... tastes more like an extender issue. Can't see an obvious reason why a single SSID can't be extended. Not the best idea to piggy back on a bug report in an off-topic section.
Giancarlo2021
May 19, 2021Aspirant
Hi, this morning I solved my problems: I insert in the extender AX1800 a static IP address, the address of the GW, DNS address (the router address, 192.168.1.1) and the mask; moreover I upload the V1.0.2.30 version of firmware (it had the .28).
now it works well
thank you
