netgruser's avatar
netgruser
Follower
Feb 02, 2024
WAX202 AP Mode + IP address conflict
I've noticed something on my network since adding the WAX202 router in AP mode.  It seems to cause ip conflicts with certain devices.  Looking at said device's logs, it shows the mac address of the WAX202 router claiming the ip address the device should have.  The device sees it has a conflict and then gives up and goes off the network.  These devices are set up as static routes.  The WAX202 router does not have dhcp turned on and its LAN address was set manually.  I seen someone post a similar issue on reddit.  Is this a bug or is something set up incorrectly?  One thought (separate issue I recall) is someone stated that routers will sometimes release their ip address and try to obtain a new one daily typically in the early morning hours.  Again, the ip on the WAX202 router is static so I doubt it's an issue unless something is hardcoded in the router.  Thanks in advanced for any help.
1 Reply
  • schumaku's avatar
    schumaku
    Very vague at least, the reddit post looks more informative: Problems with Netgear WAX202 in AP mode: DHCP server, wifi unstable, channel selection  A typical issue for a device born as a router, and then re-purposed as an access point, hiding controls in an area not accessible in AP mode. Does read like a bigger problem or two at least, to be addressed by Netgear.
    Have neither a WAX202 nor a very similar WAX206 as not sold or offered second-hand very often here in Switzerland.
ProSupport for Business
