tri4autism
Apr 12, 2022Follower
WAX204 - Signal strength issue ???
I bought the WAX204 router/ap for a small apartment... it's two rooms and like 800sq/ft. Initially I had good connectivity in the room with the router of course and the bedroom/bathroom of the apart...
Apr 12, 2022Guru - Experienced User
Did you try changing which wifi channel you were broadcasting on? Maybe there's interference?
Also, one thing to check is apartments tend to be made from materials that block wifi well (like brick/concrete). Try to make sure that those aren't in line with router/devices for good connection.
