TimoG
Feb 24, 2025Aspirant
WAX206 used as AP doesn't put through data speed higher than 100 mbps. How can i change this?
Hi community, I use a WAX206 as an Wifi Access Point in my living room. The data speed arriving at the AP from my router is lower (100 mbps up/down) than it should be (400 mbps up/down). I would ...
TimoG
Feb 25, 2025Aspirant
Thanks for your answer.
But unfortunately I already did that:
- tested the direct connection between the source (router) and my laptop via a cat6 cable. result: 400 mbps speed on my laptop
- tested the direct connection between the router and the Netgear AP with the same cat6 cable. Result: 100 mbps on the AP (outgoing cable connection as well as wifi connection)
- tested again the direct connection between the router and my laptop via a cat6 cable. result: 400 mbps speed on my laptop again.
Couldn't it be something in the AP's settings?
Feb 25, 2025Guru - Experienced User
did you try a different cable? Some devices (laptops/pcs) are more tolerant of cabling issues than routers/switches are.
are you able to log into the WAX and check its link speed between router/wax?
