AJAM
Nov 03, 2024Aspirant
WAX206 WAN Port - 1G or 2.5G?
Greetings, I own (2) of the NETGEAR WAX206 Wiress Access Point. I bought them under the premise that the WAN port that connects to the router is a 2.5 Gbps port. Since then, I have found 2 confli...
- Nov 03, 2024
The WAX206 does indeed have an Ethernet WAN port supporting 100/1000/2500Base-T Ethernet (RJ-45) port with Auto Uplink™ (Auto MDI-X).
The newer (updated bck in 2022) datsheet does correctly refer this fact, while the original one was derived from the WAX202 with five 100/1000Base-T Ethernet (RJ-45) port with Auto Uplink™ (Auto MDI-X).ports.
schumaku
Nov 03, 2024Guru - Experienced User
