TierOneTech
Nov 12, 2024Tutor
WAX214v2 power LED blinks in series of 3 blinks
I have a WAX 214v2 access point that is not connecting to the wired switch. I can access the unit through WiFi but no internet access. The unit is PoE and powers on properly. However, after bootin...
Nov 13, 2024Guru - Experienced User
What are you using to power it?
Have you tried powering it with a standard power supply to see if its a POE issue?
TierOneTech
Nov 14, 2024Tutor
Yes, I tried that with no change.
I can see both 2.4 and 5 GHZ SSID's and log into them, just no internet.
The network LED shows connected but....
- schumakuNov 14, 2024Guru - Experienced User
-> register your WAX214v2 in case this wasn't done before, then
-> select the device / serial number, and
-> follow the [Request Hardware Repalcement] process.
