mdmower
Feb 05, 2024Aspirant
WAX218 unable to omit channel 1 from 2.4GHz radio
WAX218 firmware version: 2.1.1.3 When I use the web UI to update the list of channels available to the 2.4GHz radio, the setting is not respected. After applying a channel update to remove channe...
- Feb 10, 2024
Dear mdmower
Not a set or multiset - because AP the implementation does not allow defining a set of channels for Auto operations, just the predefines sets, and one channel only. Just select -one- channel from the 2.4 GHz band - this works as designed, so put the AP for example to 6.
Odd (however feasible) an industry standard WiFi client does not connect of the AP is configured manually or dynamically to channel 1. More likely, there are massive interferences on the overloaded 2.4 GHz band.
set: https://en.wikipedia.org/wiki/Set_(abstract_data_type) ... a wonderful feature my old Professor Niklaus Wirth made popular on Pascal, Modula, .... and carried forward to Ada, C++, SQL, Java, ... too.
-Kurt
BrianL
Feb 09, 2024NETGEAR Moderator
mdmower
Feb 09, 2024Aspirant
BrianL - I tried submitting a hardware support request multiple times tonight and each time I see this response:
- schumakuFeb 10, 2024Guru - Experienced User
Forwarded this issue again (it exists since the year 2021 or longer!) to the Netgear top management these minutes. Hope this wake-up call does reach the right desks...
