mdmower
Feb 05, 2024Aspirant
WAX218 unable to omit channel 1 from 2.4GHz radio
WAX218 firmware version: 2.1.1.3 When I use the web UI to update the list of channels available to the 2.4GHz radio, the setting is not respected. After applying a channel update to remove channe...
- Feb 10, 2024
Dear mdmower
Not a set or multiset - because AP the implementation does not allow defining a set of channels for Auto operations, just the predefines sets, and one channel only. Just select -one- channel from the 2.4 GHz band - this works as designed, so put the AP for example to 6.
Odd (however feasible) an industry standard WiFi client does not connect of the AP is configured manually or dynamically to channel 1. More likely, there are massive interferences on the overloaded 2.4 GHz band.
set: https://en.wikipedia.org/wiki/Set_(abstract_data_type) ... a wonderful feature my old Professor Niklaus Wirth made popular on Pascal, Modula, .... and carried forward to Ada, C++, SQL, Java, ... too.
-Kurt
schumaku
Feb 09, 2024Guru - Experienced User
BrianL wrote:
Can you reach out to NETGEAR support to report this?
What do you expect Netgear Support should do on what is an obvious useless UI implementation?
The predefined sets for automatic are ok I guess. Interestingly, the newer work-in-progress-build I've received does still allow to deselect random channels (marked yellow). However, on [Save] I get a message (a simple text pop-up) stating "This configuration method is not supported".
In my opinion, this is not sufficient, the UI should not allow the user to deselect random channels, leading to an invalid config, and leaving back the admins in the field with questions - and the valid complaint - as coming from the OP here.
And no, I was never involved in any Beta testing for these essential APs.
mdmower
Feb 09, 2024Aspirant
schumaku - Could you suggest a channel combination that excludes channel 1 and is valid? My printer (Brother HL-L2380DW) cannot find the wireless SSID when the access point uses channel 1. It is able to find the SSID when using channel 6.
- schumakuFeb 10, 2024Guru - Experienced User
Dear mdmower
-Kurt
WAX214 and WAX218 (v1) for example:
Don't forget to [Save] and apply the changes as prompted.
- mdmowerFeb 10, 2024Aspirant
Just select -one- channel from the 2.4 GHz band - this works as designed, so put the AP for example to 6.Thanks schumaku, this works. I can choose channel 6 and the access point reliably uses only that channel after rebooting.
I tested this more, including performing a factory reset. Here's what I observe:
1. I have only two devices that attempt to use 2.4GHz: Brother HL-L2380DW and TP-Link Kasa HS107. When this issue occurs, neither device is able to find the SSID. Both of these devices reportedly use 802.11 ng mode.
1. If I configure the AP to use only channel 1 (not auto), this problem does not occur. It only occurs when I set the AP to auto select a 2.4GHz channel and the AP chooses channel 1.
1. The "1,7" auto select channel option also causes this problem.
1. I don't think this problem occurs when the Channel HT Mode is set to 20MHz. I believe I've only seen this problem with the 20MHz/40MHz setting. I haven't tested 40MHz-only mode.
Note: I live in a residential neighborhood and wifi congestion is not a problem.
- MrJoshWFeb 12, 2024NETGEAR Employee Retired
Hello,
For the RMA error, are you able to forward me the serial number and I can take a look why that error was generated?
