mdmower
Feb 06, 2024Aspirant
WAX218 unable to omit channel 1 from 2.4GHz radio
WAX218 firmware version: 2.1.1.3 When I use the web UI to update the list of channels available to the 2.4GHz radio, the setting is not respected. After applying a channel update to remove channe...
- Feb 10, 2024
Dear mdmower
Not a set or multiset - because AP the implementation does not allow defining a set of channels for Auto operations, just the predefines sets, and one channel only. Just select -one- channel from the 2.4 GHz band - this works as designed, so put the AP for example to 6.
Odd (however feasible) an industry standard WiFi client does not connect of the AP is configured manually or dynamically to channel 1. More likely, there are massive interferences on the overloaded 2.4 GHz band.
set: https://en.wikipedia.org/wiki/Set_(abstract_data_type) ... a wonderful feature my old Professor Niklaus Wirth made popular on Pascal, Modula, .... and carried forward to Ada, C++, SQL, Java, ... too.
-Kurt
mdmower
Feb 10, 2024Aspirant
Thanks schumaku, this works. I can choose channel 6 and the access point reliably uses only that channel after rebooting.
I tested this more, including performing a factory reset. Here's what I observe:
1. I have only two devices that attempt to use 2.4GHz: Brother HL-L2380DW and TP-Link Kasa HS107. When this issue occurs, neither device is able to find the SSID. Both of these devices reportedly use 802.11 ng mode.
1. If I configure the AP to use only channel 1 (not auto), this problem does not occur. It only occurs when I set the AP to auto select a 2.4GHz channel and the AP chooses channel 1.
1. The "1,7" auto select channel option also causes this problem.
1. I don't think this problem occurs when the Channel HT Mode is set to 20MHz. I believe I've only seen this problem with the 20MHz/40MHz setting. I haven't tested 40MHz-only mode.
Note: I live in a residential neighborhood and wifi congestion is not a problem.
MrJoshW
Feb 12, 2024NETGEAR Employee Retired
Hello,
For the RMA error, are you able to forward me the serial number and I can take a look why that error was generated?
- schumakuFeb 12, 2024Guru - Experienced User
No dear MrJoshW - because almost every serial number I had tried in the past failed several times, over the last 18 months - and was accepted randomly. Make IT adding some clean disgnostics and collect errors before returning a useless message - or fire this IT complete depatment NOW. There is no more time for gamling with the Netgear customer experience.
- MrJoshWFeb 12, 2024NETGEAR Employee Retired
Are you able to forward me some examples of serial numbers that were tried so I can review with the team?
Is the Netgear IT departement unable to write every attempt of submitting an RMA into a database, or for the sake into a flat list as every student coder can? Most (if not virtually all) RMA requests are coming from data the customer does select, so out of a SQL select statement LOMA. Seriosly?
- mdmowerFeb 13, 2024Aspirant
MrJoshW - I attempted to submit a hardware support request again today and still got the somethingWentWrong' error. This was in a guest profile in Chrome, so there were no extensions that could interfere. Chrome Version 121.0.6167.160 (Official Build) (64-bit)
When I look at network traffic, the form data is not sent. I see a POST to https://my.netgear.com/requesthardwarereplacement.aspx?sn=<myserialnumber> but the request body is empty.
I sent you a PM with my serial number.
