DavidVt
Sep 03, 2022Tutor
WAX620 Mesh Question
I have two WAX620's and want to set them up as mesh and both will be ethernet wired. Will they backhaul over ethernet as default, or how do I set that up.
- Sep 05, 2022
With just wired WAX6xx you don't set-up any mesh* config. Just two or more WAX6xx (or WAC5xx) on the same wired network, no mesh.
*A designation massively abused in the consumer "Mesh" network devices.
Sep 04, 2022Guru - Experienced User
You can set it up using a wired backhaul. The manual goes over the mesh setup and how to set it up starting on page 44.
https://www.netgear.com/support/product/wax620.aspx
- DavidVtSep 04, 2022Tutor
Thanks for the reply! I did see that section in the manual and got hung up on this statement:
Note: To prevent a network loop, connect the extender access point to a PoE+ switch that is not connected to the same network as the root access point or to the Internet. You can also use an optional power adapter.
Is this non wired state requirement for initial setup only, and after successful setup the extender AP can be connected to the wired network?
- schumakuSep 05, 2022Guru - Experienced User
- DavidVtSep 05, 2022Tutor
Thanks for the reply. This is what I wound up doing after trying to set up mesh and getting no good results. I did see an article that suggested to setup the second AP on a different channel.
