RCobb1
Jan 24, 2023Tutor
WAX630 and PoE question
I'm just about to add a new WAX630 to my home network in order to boost both Wifi and to restructure my network and put IoT devices on a vlan.
I have a PoE+ capable switch, but I just realized after ordering the WAX630, that it mentions PoE++... Does that indicate that I either need to upgrade the switch the WAX630 gets plugged into to a PoE++ switch? Or, will it work on a PoE+ branch just fine?
Or, is there any recommended PoE++ injectors anyone recommends if it REQUIRES PoE++ to function? Additionally, will it hurt the injector if I use an existing PoE+ port into the Injector to output PoE++? Or, would it be best to disable the PoE+ output on the port going to a new PoE++ injector?
Thanks in advance!
- RCobb1Tutor
After a lot of digging, I managed to find this doc in the FAQ section that answers my question: https://kb.netgear.com/000065156/What-happens-if-my-Insight-Managed-wireless-AP-does-not-get-enough-power-from-PoE?article=000065156
So, I ordered a PoE++ injector and will just disable the PoE+ on the switch port.Thanks!
- InfinityImagesAspirant
Hi - Which PoE++ injector did you get, and did it allow your WAX630 to operate at full power on all 3 radios bands?
- RCobb1Tutor
I ended up getting a Cudy POE400 90W Ultra PoE++ injector. And, yes, I do have all 3 bands working just fine with it, but I'll admit that I only have 1 6Ghz device, so it's the only client using that band. I've had no issues with 3 SSID's hosted on the AP; 2 of which are using all 3 bands (one IoT SSID is only using 2.4 & 5Ghz bands).
