jeconti's avatar
jeconti
Tutor
Feb 12, 2024
WAX630 constantly dissasociating a host
Hi all,
I have a WAX630, original not WAX630E. It is constantly dissociating a single host over and over. In a nonstop 30 second cycle of authentication and connecting then dissociating.
Now this device has worked flawlessly for years, but ever since upgrade from 10.7.X major release this has been happening. I do not want to downgrade due to security concerns, so I would rather troubleshoot this host.
The logs are here.
https://pastebin.com/EzgKK06Q
This is a smart wifi power strip, with routines to turn lights on and off at certain hours. It is on it's own SSID of Monoprice (Created just for this purpose) broadcasting exclusively 2.4ghz for this device. This configuration works flawlessly in older releases and if I downgrade, but once I upgrade to a 10.7 release it all breaks.
Any ideas? What can I do to fix this?
    • Pramendra's avatar
      Pramendra
      NETGEAR Expert
      Hi @jeconti ,
      We will get the logs checked on our side. In the meantime can we please try once changing the 2.4 GHz config (password) and forget the SSID on the device and try re-connecting back if that helps?
      Thanks!
      Pramendra
      NETGEAR Wireless Team
      • jeconti's avatar
        jeconti
        Tutor
        No difference on my end. Have you any other ideas or suggestions?
ProSupport for Business
