jeconti
Nov 11, 2021Tutor
WAX630 firmware update failure
WAX630 AP will not upgrade firmware, whether insight or local managed mode. New out of box firmware V9.5.1.20, shows Latest version available V9.5.4.3 but firmware update fails. When using a local ...
schumaku
Nov 11, 2021Guru - Experienced User
Not aware of any changes, try a step by step update using the earlier released version. On the WAX630 download page, https://www.netgear.com/support/product/wax630.aspx#download -> View Previous versions.
Unpacking the tar archve isn't equired, you can't uplod the individual componenta. Just expand the zip.
Avoid using "strange" tools for unzipping.
Curious: What unzip, and what client OS and Web browser? Any internet security tools or a proxy in place probably interfering with zip and/or tar archives?
- jecontiNov 12, 2021TutorWhen I locally upload the latest firmware file, attached is the error I get. I have used both an android phone running chrome and a windows 10 desktop, same result for each. Extracted like any other file using winrar.
