matt0009
May 24, 2024Follower
WAX630 Guest separate from another SSID
Hello, I added SSID (2nd) as "Guest". Can we use this guest SSID separate with 1st SSID? Is this possible for WAX630 model? thank you for in advance MTT.
schumaku
May 24, 2024Guru - Experienced User
Yes, of course.
- Either configure the Guest SSID into a dedicated VLAN (something your switch and router must support), or
- configure the Guest SSID mapped as NATed instead of bridged, so it runs on a private IP subnet within a single WAX6xx.
