matt0009
May 24, 2024Follower
WAX630 Guest separate from another SSID
Hello, I added SSID (2nd) as "Guest". Can we use this guest SSID separate with 1st SSID? Is this possible for WAX630 model? thank you for in advance MTT.
chrisjoshwa
May 29, 2024Tutor
Adding to schumaku , You can enable client isolation in the Guest SSID, so that the clients connecting to Guest, will not have communication among them and other SSID as well.
