dhi
Aug 13, 2021Follower
WAX630 LLDP PoE 802.3bt issue
Dear All Having issues with a new WAX630 not receiving the correct power from out 802.3bt PoE++ switch although i do also have WAX610 units on the same switch powered via 802.3at with no issues...
dustinm529
Jan 08, 2022Aspirant
did you ever figure this out? i am having the same issue.
four WAX630 Ap's all going into a M4250-10GxF POE++ switch and the poe settings are set to 802.3bt but the ap's are still only getting 802.3at
Thanks
Dustin
- RaghuHRJan 09, 2022NETGEAR Expert
Hi dustinm529 This is fixed. Please check the next available firmware which is scheduled to release in this week.
Raghu
- dustinm529Jan 09, 2022AspirantSweet thanks so much!
Is it for the switch or for the AP’s?
Also now the switch isn’t giving POE at all and in the POE section under “power status” it just says “power off”
Any chance I can get an early firmware update?
