tokaok2
Nov 28, 2024Aspirant
WAX630 Transmit Power and antennas
For this model the wax 630 by Netgear does anybody know the transmit power for each frequency, the spatial antenna configuration either 2x2 or 4x4, and the gain of the antennas?
schumaku
Nov 30, 2024Guru - Experienced User
Most of the wirless access points (different from mobile devices) are set to use the maximum of the regulatory allowed radiation emission power. The effective numbers might vary slightly due to different local regulation.
tokaok2 wrote:
..., the spatial antenna configuration either 2x2 or 4x4, ...
Check the fine documenttion, this is on the https://www.netgear.com/support/product/wax630/ Data Sheet for sure.
Use fellow Dr. Google and look up for the public available certification documentation under the FCC ID FMI.
